- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi y'all,
I've worked in a steel structure model in Advance Steel and now I need to export it to Revit, so that I can add some info to the elements in that model, that's why the client requires me this. I've been doing a research about adding info and an option is doing it using Navisworks, it's interoperability with Revit is fantastic when I export from Revit but doesn't work in the other way back, don't know why. I'm using Navisworks Export addon for Revit, and when I try to, it's not working. Have anyone ever try to use it? How does it work?
Thanks in advance.
Thanks in advance.
