Naviswork manage 2023 will not load previously loaded files since I upgraded my laptop to revit 2024. I get this message.
Solved by brett_parkerLUEP7. Go to Solution.
Hello
Thank you for posting to the forums.
This message is saying that "Autodesk Material Library 2023" is now missing. Unfortunately, updating to Revit 2024 has now lost that library.
As a result you will need to update Navisworks to 2024 also to align with Revit 2024.
Regards
