I'm exporting from Revit 2022 to Navisworks (nwc). I'm using Project internal coordinates. When I open the NWC in Navisworks, it looks good. The origin point matches with the Project Base Point in X and Y. The elevation on the other hand, it's exporting everything at share shared Elevation.
In Revit: PBP coordinates: 2000,6000,770
In Navisworks: 0,0,770
I want my project origin in Navisworks to be 0,0,0 - This makes it easier to check the elements elevations. But., I don't want to do any transform in Navisworks
Help
Thanks!
Am I doing something worng?
UPDATE: So I realized what was the issue. The project base point is at the 770 elevation but the internal origin is at 0,0,0. I can place the project base point anywhere I want but ultimately since the model was done 770feet above the project internal, this will never change. AND according to the Autodesk's "Customer Technical Success", I have no options. I'm very disappointed at this situation, especially after spending 30min explaining the problem to the Autodesk representative and hearing just "oh, I don't know"
