Exporter Vs Roamer.exe
Why can they not add the functionality that the exporter has to the roamer.exe? When you append a dwg into navis you wind up without some important info. Ex...in fabrication when a dwg is appended the elevation is in inches, but and nwcout  brings in the elevation with feet and inches.
davidronson
Because it is more fun to keep you guessing
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
Patrick_Aps_9121
Because the Development team refuses for years to change something to the Attach or Import technology, file readers etc.
