Excavation and tunnel galeries in a 4D simulation... how would you go ?
I have a project where I need to set up a 4D simulation representing existing ground conditions, then add the sites installations, and then a well being excavated, from the bottom of that well, we have tunnels galleries that will run horizontally and needs to be represented as well.
I need to show all that in a 4D simulation, how would you go with Navisworks (and Civil 3D)...
How would you model the terrain ? AutoCAD Solids ? or Surfaces ?...
Can we make the ground in Navis somehow transparent, so we can see what happens below ?
I am a bit struggling with how to go with this... if the best is to make my well and tunnels as hole in the surface or as solids inside the ground instead... Just need to have it looks good in animation or 4D simulation at the end...
I was also thinking about doing it in Infraworks, instead of Navisworks...
All input very welcome, and thanks for your thoughts.
Nicolas
