Engineer
Engineer
diacreek
Engineer
diacreek
After appending and saving a .nwd file (52mb) from our peer, the saved file size becomes 72 mb,
System is 2017 Navisworks Management.
Please advise how to straight it up in lieu of a new computer.
novesvalentin
Hi @diacreek,
Be aware that this always happens when you append a NWC and create an NWD, the size increaces.
See an example above of a NWC and  NWD just appending that NWC.
If this helped solve your problem please mark it as solution, so other users can get this solutions as well.
Valentin Noves
BIM Manager
www.valentinnoves.com
diacreek
Hi Valentin,
Is it safe to say same thing happens for .NWD and append / save to a new NWD as well?
novesvalentin
@diacreek
Not really, that increase in size only happens when you append a NWC to an NWD.
Best regards
Valentin Noves
BIM Manager
dgorsman
Check for rogue materials and lights (under the Render panel), and rogue saved views under the saved views panel.  I've seen files blown up in size for both instances.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
novesvalentin
That is a great comment @dgorsman, it is true that is you remove the created lights/material/lights by default and save it as a NWD that will reduce the size even making it smaller than the original NWC in some cases.
Valentin Noves
BIM Manager
