Duplicate Node Created and Transformation Identity Issue When Appending Revit Files in Navisworks 2024
jevimech
Message 1 of 1
jevimech
I am encountering an issue when appending Revit files to Navisworks 2024. When I append a Revit model, it creates a duplicate node in the selection tree. The duplicate node appears to act as an instance, but I am seeing a "transformation identity" for this node. Meanwhile, the actual transformation is applied to the node located below the duplicate in the selection tree.
This issue only occurs when appending Revit files and does not happen with other types of files. The problem seems to stem from how Navisworks is interpreting the transformations of the Revit model during the append process.
I have already tried verifying the export settings in Revit and checking the transformation data, but the issue persists. I am also working with the latest versions of both Navisworks 2024 and Revit.
Has anyone experienced a similar issue, or are there any known fixes or suggestions to resolve this behavior?
In the attached image, the highlighted nodes are where I am getting the actual transformation values.
Any help or insights would be greatly appreciated!
Best regards
Replies (0)
