Duplicate Clash Test
Message 1 of 9
Hi guys
I am trying to run duplicate test but it's not showing all elements, What I am missing!. Please check picture below.
Replies (8)
Message 2 of 9
pinaki.rajak
We need to understand first why we attempt to run duplicate clash test. The answer is, if we want to detect clash for duplicate geometry that mean we are going to check clash a model against itself to ensure the same part has not been drawn. So, as per this requirement, it is normal that we will see the clash of duplicate elements only, not all. So as per my understanding you did not missed anything.
Please reply if your requirement was something else. Or if you found that my answer helped you to clear your confusion, kindly  Kudo  and "Accept as solution". Smiley Happy
Message 3 of 9
I create duplicate element in purpose to check how it's working but i found out it's not showing all duplicated elements. But after checking yesterday also found that if two elements duplicated one of them will be joined to another element and the other is not which will lead to that navis will not read duplicate geometries. Thank you for your answer.
Message 4 of 9
pinaki.rajak
In this case, uncheck all the rules first from Clash detection Rules tab and Run the duplicate clash test one again.
Message 5 of 9
Already did, not working also
Message 6 of 9
Jacob.westergaard
Autodesk Support
Autodesk Support
Thank you for taking your time to post this on the forum,
What version and build of Navisworks are you running?
Best Regards,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Message 7 of 9
Navisworks Manage 2017
Message 8 of 9
danielcarta1982
Observer
Observer
Any update on this topic?
We have the same issue.
Regards
Message 9 of 9
yeah about that: Navisworks detect the duplicated elements if both have the same geometry (exactly the same). and what's happening if there are duplicated walls and above these walls there is a slab one of these walls will join with slab and the other won't which will lead to different in geometry between the duplicated walls. so navis can't detect every duplicated elements with present of joining....
