Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Duplicate Clash Test
12 REPLIES 12
Message 1 of 13
3106 Views, 12 Replies
Is it possible to Duplicate/Copy an Existing Clash Test?
I have a Clash Test (MEP v Structure - Basment Level 01, 02 & 03) set up and running fine and I have it organised into groups (Slabs v  Ducts, Slab v Cable Trays, etc...) and is all running fine.
I now want the same Clash Test (MEP v Structure - Basment Levels) but grouped slightly differently (Slabs B01 v  Ducts, Slab B02 v Ducts, etc...). I know I can just start a new test with the sets I have set up and regroup the new clashes, but then I will loose all results, such as Active, Resolved, Approved, Etc...
Anyone got any workarounds?
12 REPLIES 12
Message 2 of 13
Lance.Coffey
You can get a copy of an existing clash test by exporting, and the importing the current clash tests (and deleting any extras you didn't want copied as every clash test is exported and then re-imported).
However, this will not maintain the results of the clash tests.
Lance Coffey
Technical Support Specialist
Message 3 of 13
in reply to: Lance.Coffey
That doesn't really do what I want. Although that will copy the Clash Test it will not keep the Results which is one of the Items I was trying to achive.
Thanks.
Johnny.
Message 4 of 13
Lance.Coffey
You could also try creating a copy of the original Navisworks file, rename the clash test, and then merge the two files (the original and the copy).
Lance Coffey
Message 5 of 13
That might work,
Ill try this and let you kmow if it works.
Where do i add an item to a wish list as I would like to see this task in future releases
Message 6 of 13
Lance.Coffey
You can use the following link to submit a wish list item, or product feedback:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Lance Coffey
Message 7 of 13
Johnny, did this merging business work for you?
Message 8 of 13
Yes it did, it worked really well. Thank you.
It's a good tip for anyone else who reguires duplicating Clashes.
Thank you.
Johnny
Message 9 of 13
Can anyone offer a little more detail on how to do this?  I tried it and it didn't work.
In my first test I'm running fire protection against architectural, concrete, and lights.  I want to add ductwork to both sides (with the rules set to ignore items in the same file) so that I can check the FP against the duct and the duct against the building, all at the same time.
I saved the NWF with the original clash test and called the new NWF "TEST 02".  I then went to the original clash test and added the duct to both sides, re-ran the test, and closed TEST 02.  I then opened the original NWF, merged in TEST 02, but when I go to the new clash test I get all "resolved" clashes and no files highlighted in the "select" tab.
Message 10 of 13
the steps are
save your nwf
resave your nwf with a new name
in the new nwf rename your clash sets (apend the number 1 to end of set so when merged they are beside each other)
save the new nwf.
open the origional nwf
merge the two files.
Message 11 of 13
By clash "sets" do you mean "tests" or "groups"?
Not trying to be picky, but I don't know what clash sets are.
Message 12 of 13
Just to elaborate, here is what I'm getting.
Original clash test results in merged NWF.
Copied clash test results in merged NWF (note they are all yellow/resolved)
when we look at the "select" tab for the original test we see that the files are selected
but when we look at the "select" tab for the merged-in test we see that nothing is selected
If I choose the files from the left and re-run the test, all of the old groups still appear as "resolved" and all of the clashes appear as "new".
Message 13 of 13
Hi
All i can say is that if works perfectly for me. And have not got the isues you report.
If you wish to upload your nwf (including nwc's) i could test it out.
Johnny
Rail Community
