Counting number of objects in Navisworks
Dear All,
Is there a way to count the number of elements in the Navis file and export in Excel format.
Example:
I have a room, suppose I have to count the number of lights, fan and chairs an export into excel.
Thanks in advance.
a_meteni
There are various functions in Navisworks that allow you to do so:
  1. Manually select one of the items you want to count
  2. From the Select & Search panel choose Select same( type or name as appropriate)
  3. Every item with the same name/type as the selected item will also be selected
  4. Open the Selection inspector window and export your selection to a CSV file
Another way is to use the Find Items window to search for items with similar criteria. You can search for a single parameter or multiple search terms to get multiple items (i.e. Lights , fan & chairs) in one list. Then you can export into Excel as per point no.4 above.
Thanks for your solution. It works great.
Taking a step further I am trying to export the properties of those objects into an excel file. I tried exporting the object's properties using properties+ plugin. But it's not clear. Any workflow around to export them like revit schedules.
Thanks again in advance.
omarselim
u can use navisworks quantity takeoff
BIM manager with 19 years of experience.
The Universitat de BarcelonaThe Universitat de Barcelona
Master in Global BIM Management for Infrastructure Projects
Research Assistant at Qatar University
being honoured at Autodesk Digital transformation summit for the Egyptian government, for spreading and supporting the BIM culture, and community development regarding the digital transformation of the construction sector
General manager of BIMarabia Research, BIM Dictionary's
