Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Coordination Space views do not retain Transform updates
2 REPLIES 2
pobrienDUZYD
253 Views, 2 Replies
Expected behavior:
NWC from Civil engineer showing 2D linework at z = 0 opened as part of a view stored in Coordination Space.
Transform is updated to bring 2D linework up to elevation z = xxxxx.
After save, transform should stick as per normal.
Observed behavior:
NWC's z-transform is reset.
2 REPLIES 2
Thank you for raising this. Could you submit a ticket with support about this. Either via the links on this page, via a support contact or the customer support form here.
Regards
Brett Parker
Navisworks Product Manager
Will do. Just discovered a workaround for others in the same boat:
  • Performing transform directly in Model Coordination web module is permanent. Transform shows in Navisworks on next load.
Rail Community
