Hi Expert, As we know, Navisworks provides good operation for clash detection. I want to know whether it is good to support IFC file. Which means if I use clash detection function to test clash for IFC file, whether I can got correct result
Gavin
Solved by IanBadcoe. Go to Solution.
Solved by Patrick_Aps_9121. Go to Solution.
NW reads IFC files and there is no reason why you cannot clash detect with them.
One small worning, IFC files can come from many different applications and there is a lot of variation in what they export and how they structure.
If you get some typical IFCs that you want to use, load them into NW and inspect them, then as long as the you see everything you expect to see in NW, then you should be good to go.
Ian
