Background will not change
BSchwartzkopf
Message 1 of 12
BSchwartzkopf
How can I get the background to change? Right now all I get is a gray background. I try to change it in the right click menu but the background will not change at all.
Replies (11)
Message 2 of 12
Patrick_Aps_9121
Under the pannel "View" there is a button "Background" and that is where you can select the color or gradient of your background.
Message 3 of 12
BSchwartzkopf
Nope that does not work either. I have been using Navisworks since it was Jetstream so I have looked into all of the "obvious" causes I just cant find the reason I can't change my background.
Message 4 of 12
dgorsman
Full rendered or shaded view style?
Message 5 of 12
BSchwartzkopf
Full Rendered
Message 6 of 12
porterja
Good Morning  BSchwartzkopf,
Thank you for contributing to the Autodesk Community! I understand you are unable to change the background in Navisworks Manage 2016. Please refer to the following links in hopes to resolve the issue and for more information:
If you'd like to send a screencast along with the file in question so I may troubleshoot further, feel free to click on my screenname porterja and then on Send Private Message.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best Regards,
Jarrett Porter
Autodesk Technical Support
Jarrett Porter
Technical Support Specialist
Message 7 of 12
dgorsman
Do you have the Sun and Sky turned on?
Message 8 of 12
doesnt work with full render, try shaded.
Best,
Message 9 of 12
dhanraj.vyas
I had the same issue. Using Shaded instead of Full Render should solve this.
Message 10 of 12
matej_zavrsan
you must in Render / Autodesk Rendering / disabled the Sun icon. (Navis Manage 2019)
Message 11 of 12
Thank you
Message 12 of 12
ravi_kumar1VH9F3
Go to the following article it will help you to solve the issue: How to set plain background in Navisworks
