Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Appearance Profiler
1 REPLY 1
neve
330 Views, 1 Reply
Appearance Profiler
Is it possible to merge 2 or more appearance profiles together? Right now I have 3 appearance profilers  (.dat files) from different contractors and want to merge them all together to make 1 appearance profile that I can run on this project.
Nathan
1 REPLY 1
filipefrancisco
in reply to: neve
I Don't think that is possible...
Upload all 3 .dat to a project, and them export new one with everything you want
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Rail Community
