Message 1 of 1
System.IO.FileNotFoundException was unhandled
06:13 AM
Hi. I am refering to Nw_Single_Doc_With_View in Navisworks 2016 API Training Labs.
I have added the Autodesk references DLL and set both of them as false in "Copy Local" property.
When I try to run the project, I got an error message saying:
System.IO.FileNotFoundException was unhandled Message: An unhandled exception of type 'System.IO.FileNotFoundException' occurred in mscorlib.dll Additional information: Could not load file or assembly 'Autodesk.Navisworks.Controls, Version=14.0.1298.75, Culture=neutral, PublicKeyToken=d85e58fa5af9b484' or one of its dependencies. The system cannot find the file specified.
And when I try to view "Viewer.cs" [Design] page,I got an error message saying as followed:
Severity Code Description Project File Line Suppression State Message Could not find type 'Autodesk.Navisworks.Api.Controls.DocumentControl'. Please make sure that the assembly that contains this type is referenced. If this type is a part of your development project, make sure that the project has been successfully built using settings for your current platform or Any CPU. 0 Message Could not find type 'Autodesk.Navisworks.Api.Controls.ViewControl'. Please make sure that the assembly that contains this type is referenced. If this type is a part of your development project, make sure that the project has been successfully built using settings for your current platform or Any CPU. 0 Message The variable 'viewControl' is either undeclared or was never assigned. C:\Users\Joe\Autodesk\Navisworks_2016_API_Training_Labs\Indivudual labs\Nw_Single_Doc_With_View\Viewer.Designer.cs 150
I have attached several screenshots and sample project for your refernce.
For your info, my computer is a Windows 7 64 bit.
Could you tell me why I got this error and how can I solve it?
Thank you
