Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Read nwd,nwc,nwf Data
7 REPLIES 7
Message 1 of 8
1414 Views, 7 Replies
Are there any API Provided by Navisworks to read nwd ,nwc,nwf files.
7 REPLIES 7
Message 2 of 8
what data? the properties? Yes. plenty of resource on this forum explaining that.
Using the PropertiesCategory and DataProperty class.
To write data you will need to use the COM API. Also plenty of resources on this forum and the AEC blog.
Message 3 of 8
I am fine using COM API . Can you help me in getting the Free SDK and some working examples which will make it easier for me to start reading nwd,nwc,nwf data
Message 4 of 8
Search the forum for SDK and you'll find it.
Search the forum for Samples and you'll find some. You will also find sample with the SDK.
Search the forum for Properties and you'll find information.
Message 5 of 8
Does navisworks have COM API or .net api. I want to use the API from C++ application. Is there a way??
Message 6 of 8
It has both COM and .Net, but the COM has more functions but is a bit harder to read / use.
I don't know C++, but I would assume that you can to do some wizardry to load the dll into a C++ app.
Message 7 of 8
xiaodong_liang
Navisworks provides COM API, .NET API and NwCreate(C++)
COM API was introduced long time ago. It can access document and model. Similar abilities like UI. It is now maintained only. It is going to be retired in the future.
.NET API is wrapped from core code. It can access document and model. Similar abilities like UI. It follows Microsoft .NET framework guidelines. It has many equivalent abilities like COM API and also much more features than COM API such as Ribbon, document database, Timeliner, client graphics, interactive event, comprehensive abilities of viewpoint, clashtest etc. So in this perspective, I do not agree what ngombault mentioned in message 6" It has both COM and .Net, but the COM has more functions..".
In addition, even if some abilities that .NET has not while COM has (such as hyperlink, label, getting primitives of object), we can still use .NET to access these abilities by COM interop.
As to NwCreate, it is different to COM/.NET. it allows developer to create custom scene + geometry or custom loader that translates the 3rd file format.
So, if you just want to access the data (such as propertyes, model tree, viewpoints, seletcionset, timeliner, clashtes…), use .NET API.
As a start, please take a look at:
http://download.autodesk.com/media/adn/Navisworks_2011_API_Webcast-Sept2010.zip
and download the SDK Ngombault mentioned.
And for spefici requirement, search on forum or our global blog:
http://adndevblog.typepad.com/
Message 8 of 8
Good summary, I only use the COM to fill gaps in .net hence why I assumed it was more complete. Thanks for the clarification.
Rail Community
