Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Plugin does not appear on the UI
3 REPLIES 3
2736 Views, 3 Replies
There is a very weird thing going on. I have a developed plugin that runs and compiles perfectly, but when I click the "Start" button and Navisworks opens, the plugin is not in the Navisworks UI.
The output path is already set to the C:\Program Files\Autodesk\Navisworks Manage 2018\Plugins\name\
The name matches the Folder Name where the project is saved and the external program has the correct path.
The weird thing is that I have another plugin and I do exactly the same I do with this one, and one of them shows and the other one does not.
Any ideas?
Tags (4)
3 REPLIES 3
@xiaodong_liang any ideas?
Found the answer!
Just in case this is going to help someone in the future.
The solution was to modify the "Post-build event command line:" to this:
set path=path of your xaml file
set addinPath=path of the output path
set addinPath1=path of the instructions of the language in the output path
mkdir "%addinPath1%"
copy /Y "%path%" "%addinPath%"
copy /Y "%path%" "%addinPath1%"
Hoe this helps
huue_27
hi you can change you first param like this.
when different Plugin has the same value for first param your plugin will not appear on you ui
Rail Community
