Navisworks download files are getting stuck during extraction. Tried to download different times and run but would get stuck every time on different pcs. Please post when this is fixed
is that an issue when you ran any API code? if not, then it is a product question which should be posted on http://forums.autodesk.com/t5/navisworks-forum/bd-p/372
Thank you for your understanding!
HI Mr.Liang,
Thanks for the posts
I am trying basic example, SDK, 2017,
PluginSimpleExample.dll
Not available in API
b) Run nwregasm.bat followed by the name of the plugin DLL to register it.
(e.g. Select "Start" > "Run" and type: nwregasm.bat "c:\program files\Autodesk\Navisworks Manage 2017\api\com\examples\Plugin\PluginSimpleExample\bin\Debug\PluginSimpleExample.dll")
HRMoezi@yahoo.com
