I found on GitHub this code about auto-publish models I want it to work there is an option?
and how I am using it 🙂
using System;
using System.IO;
using System.Linq;
using System.Text;
using Autodesk.Navisworks.Api;
using Autodesk.Navisworks.Api.Controls;
using ReviewConverter.Properties;
using NwApplication = Autodesk.Navisworks.Api.Automation.NavisworksApplication;
namespace ReviewConverter
class NavisWorks
public static void NwdPublish(string input, string output, int vers = 2012)
// Set the job variables
var startDir = Directory.GetParent(input);
var jobName = Path.GetFileName(input);
var jobTitle = Path.GetFileNameWithoutExtension(input);
var jobDate = new FileInfo(input).CreationTime.ToString("yyyy-MM-dd");
var tempDir = Path.Combine(Environment.GetEnvironmentVariable("TEMP"), jobTitle);
var tempOutput = Path.Combine(tempDir, Path.GetFileName(output));
if (jobName == null)
Program.ConsoleLog("Error setting job variables");
return;
// Clear the temp directory
if (Directory.Exists(tempDir))
Directory.Delete(tempDir, true);
Directory.CreateDirectory(tempDir);
// Get all the working files
var workingFiles = startDir.EnumerateFiles(jobTitle + "*", SearchOption.TopDirectoryOnly).ToList();
// Remove NWC and NWD files
for (var i = workingFiles.Count - 1; i >= 0; i--)
if (!workingFiles[i].Extension.Equals(".nwc", StringComparison.CurrentCultureIgnoreCase) &&
!workingFiles[i].Extension.Equals(".nwd", StringComparison.CurrentCultureIgnoreCase))
continue;
workingFiles.RemoveAt(i);
// Copy the work files to the temp directory
Program.ConsoleLog("Copying working files...");
workingFiles.ForEach(x => x.CopyTo(Path.Combine(tempDir, x.Name)));
// Initialize the API
Program.ConsoleLog("Initializing NavisWorks...");
Program.ConsoleFreeze("Loading Navisworks modules...");
ApplicationControl.ApplicationType = ApplicationType.SingleDocument;
ApplicationControl.Initialize();
if (!ApplicationControl.IsInitialized)
Program.ConsoleLog("Unable to initialize Navisworks!");
return;
Program.ConsoleThaw();
// Get the publish properties from the provided dictionary
var publishProps = GetPublishProperties(string.Format("{0}_{1}", jobName, jobDate));
if (publishProps == null)
Program.ConsoleLog("Failed to create publish properties!");
goto Terminate;
// Create a document control
using (var docControl = new DocumentControl())
// Set the control as the primary document
docControl.SetAsMainDocument();
var nwDoc = docControl.Document;
// Try opening the document
Program.ConsoleLog("Opening {0}...", jobName);
try
{ nwDoc.OpenFile(Path.Combine(tempDir, jobName)); }
catch (DocumentFileException ex)
Program.ConsoleLog(ex.Message);
goto Terminate;
// Try publishing the document
Program.ConsoleLog("Publishing {0}...", Path.GetFileName(output));
try { nwDoc.PublishFile(tempOutput, publishProps); }
goto Terminate;
// Convert to a lower format if necessary
if (vers < 2012)
Program.ConsoleLog("Converting {0} to {1} format...", Path.GetFileName(output), vers);
try
nwDoc.OpenFile(tempOutput);
nwDoc.SaveFile(tempOutput, GetVersion(vers));
// Terminate the API
Terminate:
Program.ConsoleLog("Closing NavisWorks...");
Program.ConsoleFreeze("Unloading Navisworks modules...");
ApplicationControl.Terminate();
// Copy the file to the final location
//Program.ConsoleLog("Copying {0} to {1}", Path.GetFileName(output), Path.GetDirectoryName(output));
try { File.Copy(tempOutput, output, true); }
catch (IOException ex) { Program.ConsoleLog(ex.Message); }
public static void MergeFiles(string[] sources, string destination, int vers = 2012)
using (var nwDocControl = new DocumentControl())
nwDocControl.SetAsMainDocument();
var nwDoc = nwDocControl.Document;
// Merge
Program.ConsoleLog("Merging files...");
if (nwDoc.TryMergeFiles(sources))
Program.ConsoleLog("Merge Successful!");
// Save
Program.ConsoleLog("Saving {0}...", destination);
if (nwDoc.TrySaveFile(destination, GetVersion(vers)))
Program.ConsoleLog("{0} Saved successfully!", destination);
private static PublishProperties GetPublishProperties(string jobTitle)
var returnProperties = new PublishProperties
Author = Settings.Default.NWD_AUTHOR,
Comments = Settings.Default.NWD_COMMENTS,
Copyright = Settings.Default.NWD_COPYRIGHT,
Keywords = Settings.Default.NWD_KEYWORDS,
PublishDate = DateTime.Now,
PublishedFor = Settings.Default.NWD_PUBLISHEDFOR,
Publisher = Settings.Default.NWD_PUBLISHER,
Subject = Settings.Default.NWD_SUBJECT,
Title = jobTitle,
AllowResave = true
return returnProperties;
private static DocumentFileVersion GetVersion(int vers)
switch (vers)
case 2010: return DocumentFileVersion.Navisworks2010;
case 2011: return DocumentFileVersion.Navisworks2011;
case 2012: return DocumentFileVersion.Navisworks2012;
default: return DocumentFileVersion.Current;
public static DocumentFileVersion GetVersion(string filePath)
// Create the byte buffer
var buffer = new byte[1024];
// Create the search pattern (Navisworks:)
byte[] pattern = { 110, 97, 118, 105, 115, 119, 111, 114, 107, 115, 58 };
// Create the version byte array
var version = new byte[3];
// Load the NWD file
using (var fs = new FileStream(filePath, FileMode.Open, FileAccess.Read))
// Read the bytes into the buffer
fs.Read(buffer, 0, buffer.Length);
// Get the pattern start position
int patternStart = IndexOfSequence(buffer, pattern, 0);
// If the pattern wasn't found in the header
if (patternStart == -1)
// Go the the end of the file
fs.Seek(-buffer.Length, SeekOrigin.End);
// Return default if the pattern is still not found
if (patternStart == -1) return DocumentFileVersion.Current;
// Get the version start position
int versionStart = patternStart + pattern.Length;
// Copy the version bytes (3) into the version byte array
Array.Copy(buffer, versionStart, version, 0, version.Length);
// Get the integer representation of the version
var vers = int.Parse(Encoding.ASCII.GetString(version));
// Return the DocumentFileVersion parsed from the integer
return (DocumentFileVersion)vers;
// Returns the start position of a byte pattern within a byte array
private static int IndexOfSequence(byte[] buffer, byte[] pattern, int startIndex)
// Find a starting point matching the first pattern element
var i = Array.IndexOf(buffer, pattern[0], startIndex);
// Iterate through the length of the buffer
while (i >= 0 && i <= buffer.Length - pattern.Length)
// Create a byte block of the pattern size
var segment = new byte[pattern.Length];
// Copy the bytes from the ith position into the segment
Buffer.BlockCopy(buffer, i, segment, 0, pattern.Length);
// Return the current position if the sequeence is a match
if (segment.SequenceEqual(pattern))
return i;
// Otherwise increment i a full pattern length
i = Array.IndexOf(buffer, pattern[0], i + pattern.Length);
// Return no pattern found
return -1;
Hi @gal.aG8RRW ,
What do you mean by "you want it to work"?
Create an instance of class NavisWorks and call the required methods inside the class instance by passing the required values.
I would suggest you take a look at the "NET\examples\Controls\PublishFile" sample present in the Navisworks SDK.
You can download SDK from the below link
https://www.autodesk.com/developer-network/platform-technologies/navisworks
I hope this helps.
