I'd like my plugin to automatically use the information on the INTERFACE -> DISPLAY UNITS page (Linear Units, Decimal Places, and Fractional Display Precision) so I can format my text boxes to match the users current setup...but I can't figure out where these values are stored.
Is this something I'm able to do? If so, where is the data stored?
I was thinking I could read from a pre-existing config file if I had to, but nothing I saw contained this data either. I think I'm just blind?
edit:
So it looks like I might have found where to start: Autodesk.Navisworks.Internal.ApiImplementation.ApplicationConfig... or not.
Solved by xiaodong_liang. Go to Solution.
The officcial .NET API has not exposed the abilities with Global Options. You could get the values from registry at:
HKEY_CURRENT_USER\Software\Autodesk\Navisworks Manage x64\11.0\GlobalOptions\interface\disp_units
Additionally, does the API currently expose the ability to access the specific per file/model unit as specified under the "Units and Transform" dialog accessable via the Selection Tree?
Somewhy in NW Manage x64 2014 GlobalOptions doesn't exist at HKEY_CURRENT_USER\Software\Autodesk\Navisworks Manage x64\11.0\ on Windows 8 machine. Can these settings be hiden elsewhere?
You can read it.
This is for converting to mm:
double conv = UnitConversion.ScaleFactor(Application.MainDocument.Units, Units.Millimeters);
