Event selecting objects api c#
AronNill
AronNill
Hello everyone!
I want to implement a modified property menu, which, when I select an item, will list the properties I need. But I could not find an event that will pass on to my plugin object id when it is selected. Can you suggest a task event or how can this be implemented for api c# wpf? Thank.
DHANANJAYKRPANDEYUZB9X
Use this event  Application.ActiveDocument.CurrentSelection.Changed += CurrentSelection_Changed;
When ever u selected any component (item ) from screen this event fired.
Only one condition your plugin form should be open where you are going to used
