.NET API - cannot load the DLL files
I am trying to use the API but every time I run my application, it comes up with the following errors depending on which "Platform target" option I choose.
This is my simple program:
using System;
using Autodesk.Navisworks.Api;
namespace ConsoleApp4
    class Program
        static void Main(string[] args)
            Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
            Console.WriteLine(doc.Title);
The DLL files are located in "C:\Program Files\Autodesk\Navisworks Manage 2019" where I load them from. See below:
I tried to copy the files to a different folder - this does not help. I also have a full professional licence. Any ideas how to make this work?
xiaodong_liang
Autodesk Support
Autodesk Support
Hi @Anonymous ,
if you wanted to build a standalone EXE program(such as Console or Winform ), you will need to work with Automation API + Plugin API of Navisworks
if you wanted to build a plugin only, you will need to build a class, instead of Console or Winform or else.
if you wanted to build a standalone EXE program with Viewer, you will need to work with .NET Control API.
I would suggest you take a look at the basic tutorial of Navisworks API:
http://images.autodesk.com/adsk/files/Navisworks_Training_Labs_2015_0921.zip
