Is there any way of creating tags like below using the C# API ?
https://help.autodesk.com/view/NAV/2023/ENU/?guid=GUID-E58E6979-EA8D-4C58-BAA2-2879BD493420
Solved by lanneauolivier. Go to Solution.
Hi @igor.barcelosC54YD ,
Please take a look at this below code
Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
Autodesk.Navisworks.Api.View view = doc.ActiveView;
string getRedLines = view.GetRedlines();
// The value of "getRedLines" will resemble the value I've set in the "s" variable.
// By adjusting the value of "s", you can customize your own set of red lines.
string s = "{\"Type\":\"RedlineCollection\",\"Version\":1,\"Values\":[{\"Type\":\"RedlineEllipse\",\"Version\":1,\"Thickness\":3,\"Color\":[1,0,0],\"MinPoint\":[-0.45388908606868772,0.3369782608691772],\"MaxPoint\":[0.54593652310359631,-0.2248285099990586]}]}";
view.TrySetRedlines(s);
Hi, thanks a lot for your return.
if I may, I have two more questions :
1/ I could drawn the circle with your code like shown in the image below. The problem is that when I change the camera (scrolling or padding) the ellips dissapears. How can I append this to the current view ?
2/ My final goal is to achieve an similar result as the 'markups' in Forge like below. Any ideas ? Going with the redLines is an good idea ?
Thank you !
You must use RenderPlugin for it. It allows you to draw over the render in 3D or in 2D.
