Hi there,
I hope you are well.
I am wondering if there is a way via API to select selection/search set when applying Selection A and Selection B on ClashTest?
At the minute what I do is the following (python).
# allsetinfolder are all the set I have in the nwf, below I am getting the first and the second as an example #
f = allsetinfolder[0].GetSelectedItems() s = allsetinfolder[1].GetSelectedItems() ######################### clash ######################## doclash = doc.Clash alltd = doclash.TestsData ftest = alltd.Tests[0] copy = ftest.CreateCopy() copy.SelectionA.Selection.CopyFrom(f) copy.SelectionB.Selection.CopyFrom(s)
# When I do the above as I am using GetSelectedItem, I am doing an ModelItem Collection #
So it is display like:
Which is correct, it is taking all the walls and Doors.
However what I am after is to be displayed by Selection Set as:
Thank you very much in advance
I am trying to figure out the same... Also no luck for the moment. A little bit sad, but i am considering to first make an xml for the clashtests and import that. Like that it is possible.
var sourceCollectionA = new SelectionSourceCollection();
var sourceCollectionB = new SelectionSourceCollection();
foreach (var savedItem in doc.SelectionSets.Value)
foreach (var selectionSet in GetSelectionSets(savedItem, group1.SearchSets.ToList()))
sourceCollectionA.Add(doc.SelectionSets.CreateSelectionSource(selectionSet));
foreach (var selectionSet in GetSelectionSets(savedItem, group2.SearchSets.ToList()))
sourceCollectionB.Add(doc.SelectionSets.CreateSelectionSource(selectionSet));
clashTest.SelectionA.Selection.CopyFrom(sourceCollectionA);
clashTest.SelectionB.Selection.CopyFrom(sourceCollectionB);
This method is not from the API and is not important for the question. The method returns sets of search queries
