Use NWCreate API in C# .NET?
Hello
Can you use the NWCreate API in C# .Net? Or can it only be used in C++? I am aware I can produce a DLL (from C++ NWCreate code) and access this from .NET C# code but its much easier to have 1 code base.
xiaodong_liang
Autodesk Support
Autodesk Support
sorry NwCreate has not .NET version. wrapping the C++ code and call it from .NET is the way at this moment.
in addition, if you are working with.NET plugin, one more thing you will need to be aware:
http://adndevblog.typepad.com/aec/2012/05/nwcreate-with-net-plug-in.html
