Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
troubleshooting naviswork TimeLiner connection to Primavera P6 via WebServices
p.dimascio
Observer Observer
Message 1 of 1
p.dimascio
Observer
Observer
Hi all,
i have a Primavera P6 (EPPM v.20.12) installed on-Premise, completely working with webServices running.
I'm trying to connect the Navisworks's TimeLiner just by adding the connection as simple as is.
I tryed to use the SSL port, the standard port, the webservices port, but none has worked.
The error while using the standard / SSL ports is:
"Connection interrupted by he host computer"
The error while using the WebServices port is:
"WSS header is missing from request. Can't do username token authentication"
There is also an anomaly: the errors above are notificated only after the first attempt, from the second attempt with the exact same parameters Naviskworks say:
"...Status code HTTP 404: NOT FOUND"
Obviously everything is fine when using file import with .CSV o .MPP, but i need to connect directly the timeliner.
Someone facing the same problem?
Thankyou very much.
Peter
Replies (0)
