To Run a Clash test using api
Inside a plugin, I am creating a new clash test and trying to run it. Using this command "documentClash.TestsData.TestsRunAllTests();" it runs without any errors. However, if I try using "documentClash.TestsData.TestsRunTest(oTest);" where oTest is the newly created instance, it throws "ArgumentException Argument is not in Clash Detective Parameter name: test". No other tests are defined in the model !
SavedItemCollection clashTests = documentClash.TestsData.Tests;
documentClash.TestsData.TestsRunTest(clashTests[clashTests.Count-1] as ClashTest);
jabowabo
You can also try this:
 private void RunClash(string clashTestName)
            Document doc = NavisApp.ActiveDocument;
            DocumentClash clash = doc.GetClash();
            DocumentClashTests clashTests = clash.TestsData;
            using (ClashTest clashTest = (ClashTest)clashTests.Tests.FirstOrDefault(t => t.DisplayName == clashTestName))
                clash.TestsData.TestsRunTest(clashTest);
Ta7a
Hello jabowabo,
this method is really great but i have a small issue if i get test and try to run it the object of this test is disposed and i can't use it ( i remove using block to avoid disposing of clashtest but it still disposed)
