System.IO.FileNotFoundException was unhandled
Message 1 of 1
Hi. I am refering to Nw_Single_Doc_With_View in Navisworks 2016 API Training Labs.
I have added the Autodesk references DLL and set both of them as false in "Copy Local" property.
When I try to run the project, I got an error message saying:
Message: An unhandled exception of type 'System.IO.FileNotFoundException' occurred in mscorlib.dll
Additional information: Could not load file or assembly 'Autodesk.Navisworks.Controls, Version=14.0.1298.75, Culture=neutral, PublicKeyToken=d85e58fa5af9b484' or one of its dependencies. The system cannot find the file specified.
And when I try to view "Viewer.cs" [Design] page,I got an error message saying as followed:
Severity	Code	Description	Project	File	Line	Suppression State
Message		Could not find type 'Autodesk.Navisworks.Api.Controls.DocumentControl'.  Please make sure that the assembly that contains this type is referenced.  If this type is a part of your development project, make sure that the project has been successfully built using settings for your current platform or Any CPU.			0
Message		Could not find type 'Autodesk.Navisworks.Api.Controls.ViewControl'.  Please make sure that the assembly that contains this type is referenced.  If this type is a part of your development project, make sure that the project has been successfully built using settings for your current platform or Any CPU.			0
Message		The variable 'viewControl' is either undeclared or was never assigned.		C:\Users\Joe\Autodesk\Navisworks_2016_API_Training_Labs\Indivudual labs\Nw_Single_Doc_With_View\Viewer.Designer.cs	150
I have attached several screenshots and sample project for your refernce.
For your info, my computer is a Windows 7 64 bit.
Could you tell me why I got this error and how can I solve it?
Thank you
Replies (0)
