Setting the center point of modelitem
thomas.channell
thomas.channell
I am new to the Navisworks API and have found although I can get the centre point of a bounding box of an object, I can't set to or change these values.
I may just be missing something?
Thanks in advance,
Tom
xiaodong_liang
Autodesk Support
Autodesk Support
boundingbox is fixed property with a model geometry. Could you clarify why you wanted to change center of boundingbox?
or probably you just wanted to transform a geometry? if yes, please refer to this blog:
http://adndevblog.typepad.com/aec/2013/05/navisworks-2014-api-new-feature-override-transformation.ht...
thomas.channell
I am having no problem with transforming the object, however I am looking to rotate the model around a different point other than the center of the bounding box given, therefore I am attempting to alter this position.
Hope this makes sense?
Tom
xiaodongliang
Hi Tom,
so, it sounds like what you wanted to set it pivot of orbit the scene?  I need to check if API is available, but I'd like to have your confirmation on my understanding of your question.
thomas.channell
Yes this would be a solution to our problem.
Tom
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry I do not find an API, and has not got a comment from our engineer team. So I logged a wish# NW-53280: NET API: set pivot of orbit
thomas.channell
Thanks for looking into this :).
