Setting File Options Up- and North-orientation Using Navisworks API
Suresh3705
Suresh3705
We were trying to update the orientation values for  Up & North programmatically, we can be able to get the Up & North vector from the model object but can't able to set its value, Is there any way to put those values?
Attached is a similar post related to this,
Setting-file-options-up-and-north-orientation-programmatically
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Suresh3705 ,
I checked with the Navisworks Engineering team.
Looks like, Currently, these values cannot be modified via the .NET API.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
sundar_ramu
Observer
Observer
0,1,0
0,0,1
werner_richtsfeld
are there any updates regarding updating these options?
Is there a way to provide an API call (or is there an existing one?) for the same action which is executed when pressing the defaults button?
