Set Viewpoint Position Using command line
yasikmondal21
yasikmondal21
Hello Team.
 How I can set the viewpoint position using command line while opening nwd file.  I am trying using the below script.
Position.Test : this is the plugin file where I have created  to set the view point position. but I want to send this using command line arguments.
tetsuya_miwa
Assuming oPoint is Point3D from command arguments.
    Document oDoc = Autodesk.Navisworks.Api.Application.ActiveDocument;
    Viewpoint oCurrVCopy = oDoc.CurrentViewpoint.CreateCopy;
    oCurrVCopy.PointAt(oPoint);
    oDoc.CurrentViewpoint.CopyFrom(oCurrVCopy);
yasikmondal21
Hello @tetsuya_miwa ,
I am trying to open navis work from batch file .
If I install navisworks first time by default there wont be any plugin available. So I can create the plugin from command line ? or is there any way to generate this? I am not using any asp .net application.
tetsuya_miwa
Create your own plugin by c# or VB.net and place the dll file in the correct folder.
Navisworks will load it automatically.
yasikmondal21
If i copy this dll plugin and paste it somwhere then how i will define the plugin path in command.. can you give me that command line arguments
tetsuya_miwa
Not somewhere. The default place of plugin is stricktly fixed. Then  command line arguments can find corresponding plugin by class name only.
https://www.youtube.com/watch?v=mLsQFW5dV2w
yasikmondal21
Thanks for information  @tetsuya_miwa  and it working for me. 🙂
Do we have any arguments where I can pass strage url of nwd file ? as this is a big file and we cant donwload everytime. So I wanted to use CDN or Azure Storage for avoid multiple downlaod.
"%userprofile%\NavisProject\100000000715815-1000.nwd" --> how to provide network file which are present in either LAN storage or Azure Storage.?
