Search name constant contain string
Message 1 of 24
Dear all,
I want to search the elements that has a name constant property.
For example,
Category: Element
Property: Phase Created
Value: Phase "New Construction", #86961
How can I search this element with only a keyword "New"?
I tried to search through below code, but nothing returns.
SearchCondition.HasPropertyByDisplayName("Element""Phase Created").DisplayStringContains("New").IgnoreStringValueCase()
Best Regards,
John
Replies (23)
Message 21 of 24
Hi XiaoDong,
A sample model is uploaded for you to test.
There are serveral elements with the property 'Phased Created'.
Hi Ulski,
Yes, this is the only solution I found. However, the performance is not good. Thus, I hope to find another solution from Xiaodong.
Best Regards,
John
Message 22 of 24
xiaodong_liang
Autodesk Support
Autodesk Support
Hi John,
The value of Element >> Phase Created is a NamedConstant. My code demo in message 10 does not apply because I thought it is just a string or something that can be converted to string. The issue can be reproduced at my side. i.e. LINQ seems not working with NamedConstant.
In addition, if checking by SDK sample AppInfo, it shows NamedCosntant.Value is exactly the value we saw in property panel (AppInfo uses reflection to get object attributes.)  while if checking by API, NamedCosntant.Value is 0, and the NamedCosntant.DisplayName is is exactly the value we saw in property panel. This is also strange to me.
I will log the issue to our engineer team. At this moment, I did not find a workaround 😞
Message 23 of 24
Hi Xiaodong,
Never mind. Thank you for investigating the problem as well as logging it.
Best Regards,
John
Message 24 of 24
xiaodong_liang
Autodesk Support
Autodesk Support
the issue that is logged NW-DID 52279
