Search name constant contain string
Message 1 of 24
Dear all,
I want to search the elements that has a name constant property.
For example,
Category: Element
Property: Phase Created
Value: Phase "New Construction", #86961
How can I search this element with only a keyword "New"?
I tried to search through below code, but nothing returns.
SearchCondition.HasPropertyByDisplayName("Element""Phase Created").DisplayStringContains("New").IgnoreStringValueCase()
Best Regards,
John
Replies (23)
Message 2 of 24
augusto.goncalves
Sorry, which API is this SearchCondition that you're using?
UPDATE: sorry, I got confused, this is a Navisworks API
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 3 of 24
ulski1
hi,
I recommend that you open and compile the dll for the Autodesk provided plugin tool called appinfo (see C:\Program Files\Autodesk\Navisworks Simulate 2016\api\NET\examples\Tools\AppInfo)
After you get this tool up and running you select the item manually you want to seach for and start the appinfo tool  - in the tool you can browse the object tree (look for selected item) and see where you search fails - that said the most likely problem is that you have to use the internal category name not the displayed category name
br
Ulrik
Message 4 of 24
Hi Augusto Goncalves,
Thanks for your interest. It is Navisworks API.
Autodesk.Navisworks.Api.Search.Conditions.
Hi Ulrik,
Thanks for your answer.
I tried to use internal name but it still doesn't work.
The problem I faced is that the value of the property is NameConstant, instead of DisplayString.
Here are one more example.
Category: Element
Property: Id
Value: 123456
How can I search this element with part of it, says '234'?
Below code returns me nothing.
SearchCondition.HasPropertyByDisplayName("Element""Id").DisplayStringContains("234").IgnoreStringValueCase()
The reason behind is the value of Element Id is Int, instead of DisplayString.
Best Regards,
John
Message 5 of 24
ulski1
hi again John,
when navisworks read data from other CAD systems Revit,AutoCad etc. it will automatically try to guess if a value is a string, integer, double or date. The number 123 is most likely a int and not a string. The values are accessed via a class  "VariantData" (look into this)
You can only use "displaystring" on things that are a string. If you want to have a search method that can handle both integer and string you should try to use ".value" instead of "displaystring". I also recommend that you read in the documentation about "PruneBelowMatch", "StartGroup" and  "Locations"
Here is a code snippet to get you started
using (VariantData MyValue = DPC.FindPropertyByName(NWDataPropertyMyProp).Value)
if (MyValue.IsDisplayString)
Result = MyValue.ToDisplayString();
else
Result = MyValue.ToString();
Ulrik
Message 6 of 24
Hi again Ulrik,
Thanks again for your detailed reply.
The main problem I faced is to search the element with part of the value.
I read the document, but there is only method 'DisplayStringContains', which works with DisplayString only, but not Int and NamedConstant.
Best Regards,
John
Message 7 of 24
ulski1
try
SearchCondition.HasPropertyByName(NWPropertyCategory, NWDataPropertyTag).StartGroup();
Message 8 of 24
ulski1
full line is something like:
searchObject.SearchConditions.Add(SearchCondition.HasPropertyByName(NWPropertyCategory, NWDataPropertyTag).StartGroup());
Message 9 of 24
This will search all the elements that have that properties.
However, I just want to search the elements with part of the value.
Message 10 of 24
xiaodongliang
Hi John,
you can use SearchConditionComparison.DisplayStringContains, orSearchConditionComparison.DisplayStringWildcard
 Search search = new Search();
search.Selection.SelectAll();
search.SearchConditions.Add(new SearchCondition(
                            new NamedConstant(PropertyCategoryNames.AutoCadEntityHandle,"Element"),
                            new NamedConstant(DataPropertyNames.AutoCadEntityHandleValue, "Phase Created"),
                            SearchConditionOptions.IgnoreNames,
                            VariantData.FromDisplayString("New")));
ModelItemCollection items = search.FindAll(Nw.Application.ActiveDocument, false);
Nw.Application.ActiveDocument.CurrentSelection.CopyFrom(items);
Or, you could also build LINQ clause
   IEnumerable<ModelItem> oMC =
             Nw.Application.ActiveDocument.Models[0].RootItem.DescendantsAndSelf.Where<ModelItem>
                (x=>x.PropertyCategories.FindPropertyByDisplayName("Element","Phase Created").Value.ToDisplayString().Contains("New"));
Message 11 of 24
xiaodong_liang
Autodesk Support
Autodesk Support
again, posted by my personal account. Do not be surprised 🙂
Message 12 of 24
Hi Xiao Dong,
Long time no chat.
I tried your codes but there is nothing returned.
I guess the problem is the the Property 'Phase Created' is a NamedConstant instead of DisplayString.
However, I cannot find a method that has the 'Contain' function for other types, such as Int32 and NamedConstant.
Best Regards,
John
Message 13 of 24
xiaodong_liang
Autodesk Support
Autodesk Support
Hi John,
will it be fine if you toString on the value and use Contain function?
Message 14 of 24
Hi XiaoDong,
It cannot be done in the Search API.
Would you mean I search all elements containing this property and use For loop to compare all items with the keyword?
Best Regards,
John
Message 15 of 24
xiaodong_liang
Autodesk Support
Autodesk Support
I meant the second way LINQ which sorts out the items from rootitem.
Message 16 of 24
Hi XiaoDong,
I tried your code, but it doesn't work.
Best Regards,
John
Message 17 of 24
ulski1
hi John,
try this:
Int32 myi = 0;
if (int.TryParse(item, out myi) == false)
//display error
else
SearchObject.SearchConditions.Add(SearchCondition.HasPropertyByName(NWPropertyCategory,NWDataProperty).EqualValue(VariantData.FromInt32(myi)).StartGroup());
br
Ulrik
Message 18 of 24
Hi Ulrik,
Thanks for your suggestion. However, this method need to search with the exact value.
For example, I want to find an element that has value '1234567',but I search nothing with keyword '3456' by your method.
Best Regards,
John
Message 19 of 24
xiaodong_liang
Autodesk Support
Autodesk Support
Hi John,
could you share a test model? I can give a test at my side.
Message 20 of 24
ulski1
I see the problem - Navisworks does not offer "contains" or "wildcard" as search criteria for numbers. You can only use "smaller than"/"larger than" etc.
I agree with Xiaodong Liang that you will have to select all objects with this number attribute and then write you own loop / filter
br
Ulrik
