Search Item > Icon = "Composite Object"
I'm trying to write a plugin that exports all elements RevitIDs along with their timeline data.
In order for it to work (on doors, windows etc.) I have to eliminate all Revit Types.
The only property I could have found for this is the Icon
Item > Icon = "Composite Object" vs. Collection and Geometry.
Is there any other more practical way for that?
Second is no matter how much I've examined sample codes and tried to write a search for this I couln't figured it out.
Please help me write a search condition for Item > Icon = "Composite Object"
Thanks in advance..
From navisworks creating a search for it works fine. When I export the search out as xml
"Composite Object" data type shows as NAME. And I couldn't find a way to mimic this search in the Api..
xiaodong_liang
Autodesk Support
Autodesk Support
If I understand correctly, you want to create a search with the condition if the item is composite object? You could use Search + LINQ to do so. e.g.
   // assume you have define a search
    IEnumerable<ModelItem> finalItems =
        search.FindAll(activeDocument,false).Where(x=> x.IsComposite);
Hope this helps.
simon.mcilhargey
Using LINQ here is prohibitively slow unfortunately, trying to say grab all the composites in a project will scale very poorly with what is effectively a for loop.
