Render Image through Navisworks API?
Hi
Is there anyway of programmatically rendering the image to a file using the API, .NET or COM?
Ideally I would like to be able to select the format (jpeg), renderer (Presenter) and Size (Explicit).
I guess it would be possible to use the DrawToBitmap method of the ViewControl but this would only allow the use of the viewport renderer, is this correct?
Many Thanks
Simon
xiaodong_liang
Autodesk Support
Autodesk Support
I do not think we have implemented DrawToBitmap which overrides from Windows .NET control.
But probably the COM API could help you, which could be called by .NET.
<2012>\api\COM\examples\ACTX_03
<2012>\api\COM\examples\ACTX_07
<2013>\api\COM\examples\ActiveX\ActiveXSnapshotExample
<2013>\api\COM\examples\Auto\AutoPresenterExample
