Plug In Ribbon tab name
nicolLSPDR
nicolLSPDR
I have looked all over the forums and can't seem to find a solution on how to change the default ribbon tab name for plug ins. I have a dll that contains 3 plug in tools and when I import them into Navisworks they appear under Tool add-in 1. I would like to rename this so that it uses my companies name instead however, I'm not sure how to accomplish this. Any help would be great.
naveen.kumar.t
Autodesk Support
Autodesk Support
My suggestion is to create your own ribbon. Please take a look at this link:https://twentytwo.space/2022/02/02/navisworks-api-commandhandlerplugin/
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
nicolLSPDR
I tried following this tutorial however I can't build the dll because of errors from my xaml file.
nicolLSPDR
This ended up being super helpful. I also used this video from youtube to help but they are essentially the same material. Along with a few typos I found my problem was I was referencing old dlls instead of the new names so now the ribbon tab works. However, the test command I built crashes the program. I'm hoping it's just the quick test I built but I will update if nothing changes.
Here is the xaml text used for those also struggling:
<?xml version="1.0" encoding="utf-8" ?>
<RibbonControl
x:Uid="AddinRibbon" xmlns="clr-namespace:Autodesk.Windows;assembly=AdWindows"
xmlns:wpf="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:adwi="clr-namespace:Autodesk.Internal.Windows;assembly=AdWindows"
xmlns:system="clr-namespace:System;assembly=mscorlib"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:local="clr-namespace:Autodesk.Navisworks.Gui.Roamer.AIRLook;assembly=navisworks.gui.roamer">
<RibbonTab Id="ID_CustomTab_1" KeyTip="T1">
<RibbonPanel x:Uid="RibbonPanel1">
<RibbonPanelSource x:Uid="RibbonPanelSource_RibbonPanel_1" KeyTip="C1" Title="Tools">
<local:NWRibbonButton x:Uid="Button_1" Id="ID_Button_1"
Size="Large"
KeyTip="B1"
ShowText="True"
Text="Button_1"
Orientation="Vertical"/>
</RibbonPanelSource>
</RibbonPanel>
</RibbonTab>
</RibbonControl>
nicolLSPDR
Youtube video for reference. https://www.youtube.com/watch?v=fbMz7roQptU
The post build portion did not work for me so I added the dll and xaml to the plug ins folder by hand myself (don't forget to add en-US folder and place the xaml in it there as  well).
