Naviswork and Prism Library Issue
Hy All,
I have developed an AddIn for AutoCAD, Civil3D and Revit which does different operations but is based on common libraries implemented with Prism library and dependency injection. I would like to implement in Naviswork as well but I can't. There appears to be a problem between Naviswork and Prism bootstrapper. I attach a simple example that does nothing but contains a class derived from PrismBootstrapper. If I comment the class the AddIn is loaded correctly if, on the other hand, I remove the comments even without creating an instance of the class the addin is no longer loaded. What can I do?
Regards
Rolando Tonin
I temporarily solved the problem by copying prism *. * in the Naviswork folder as Naviswork cannot load them from the plugin folder. Is there an option in Naviswork to assign a shared path by mapping it to the plugin folder?
Rolando
If your plugin uses any external Libraries, you need to put them in the dependencies folder (%Your_Navisworks_Installation_Localtion%\Dependencies). I don't think there is another solution for this.
Br,
geethat
It worked for me
