Hyperlink with model object change
d.fedulov
Message 1 of 8
d.fedulov
Dear Colleagues
I am looking for a possibility to change hyperlink to  individual object in Navisworks. I know that through right clicking any object, i can assign / change / load any web link. I need to change a lot of hyperlink.
Please help correct the code.
// get current selected items
        ModelItemCollection modelItemCollectionIn =
           new ModelItemCollection(
                Autodesk.Navisworks.Api.Application.ActiveDocument.
                    CurrentSelection.SelectedItems);
        //convert to InwOpSelection of COM API
        ComApi.InwOpSelection comSelectionOut =
        ComApiBridge.ComApiBridge.ToInwOpSelection(modelItemCollectionIn);
        // set the hyplerlink of the model items
        state.SetOverrideURL(comSelectionOut, oMyURLOoverride);
        // enable to the hyperlinks visible
        state.URLsEnabled = true;
Replies (7)
Message 2 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
HI @d.fedulov ,
The below sample code works fine for me
string urlLink1 = "https://www.youtube.com/";
string urlName1 = "URL A";
ModelItemCollection collection1;
MyCode(doc,urlName1,urlLink1,collection1);
string urlLink2 = "https://www.google.com/";
string urlName2 = "URL B";
ModelItemCollection collection2;
MyCode(doc, urlName2, urlLink2, collection2);
private void MyCode(Document doc,string urlName,string urlLink,ModelItemCollection collection)
            InwOpState10 state = ComApiBridge.State;
            // create the hyperlink collection
            InwURLOverride oMyURLOoverride =(InwURLOverride)state.ObjectFactory(nwEObjectType.eObjectType_nwURLOverride, null, null);
            InwURL2 oMyURL =(InwURL2)state.ObjectFactory(nwEObjectType.eObjectType_nwURL, null, null);
            oMyURL.name = urlName;
            oMyURL.URL = urlLink;
            int i = 0;
            if (i == 0)
                oMyURL.SetCategory("Hyperlink", "LcOaURLCategoryHyperlink");
            else
                oMyURL.SetCategory("Label", "LcOaURLCategoryTag");
            InwURLColl oURLColl = oMyURLOoverride.URLs();
            oURLColl.Add(oMyURL);
            InwOpSelection comSelectionOut =ComApiBridge.ToInwOpSelection(collection);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
d.fedulov
I found this code, i don't know how to change only one Hyperlink. Can't find documentation for Autodesk.Navisworks.Api.Interop.ComApi.InwURL2
https://forums.autodesk.com/t5/navisworks-api/add-multiple-urls-to-element/td-p/7786919
Autodesk.Navisworks.Api.Interop.ComApi.InwOpState10 state = Autodesk.Navisworks.Api.ComApi.ComApiBridge.State;
ModelItem modelItem = Autodesk.Navisworks.Api.Application.ActiveDocument.CurrentSelection.SelectedItems.First;
ModelItemCollection modelItemCollection = new ModelItemCollection();
modelItemCollection.Add(modelItem);
Autodesk.Navisworks.Api.Interop.ComApi.InwOpSelection opSelection = Autodesk.Navisworks.Api.ComApi.ComApiBridge.ToInwOpSelection(modelItemCollection);
if (modelItem.PropertyCategories.FindCategoryByName("LcOaExURLAttribute")==null)
Autodesk.Navisworks.Api.Interop.ComApi.InwURLOverride oMyURLOoverride =
(Autodesk.Navisworks.Api.Interop.ComApi.InwURLOverride)state.ObjectFactory
(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwURLOverride, null, null);
Autodesk.Navisworks.Api.Interop.ComApi.InwURL2 newURL = (Autodesk.Navisworks.Api.Interop.ComApi.InwURL2)state.ObjectFactory(Autodesk.Navisworks.Api.Interop.ComApi.nwEObjectType.eObjectType_nwURL, null, null);
newURL.name = "NewLink";
newURL.URL = "NewLinkURL";
newURL.SetCategory("Hyperlink", "LcOaURLCategoryHyperlink");
oMyURLOoverride.URLs().Add(newURL);
state.SetOverrideURL(opSelection, oMyURLOoverride);
else
Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath3 oPath3 =
Autodesk.Navisworks.Api.ComApi.ComApiBridge.ToInwOaPath(modelItem) as
Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath3;
Autodesk.Navisworks.Api.Interop.ComApi.InwURLOverride oURLOverride = state.GetOverrideURL(oPath3);
newURL.name = "URLName";
newURL.URL = "URL";
oURLOverride.URLs().Add(newURL);
state.SetOverrideURL(opSelection, oURLOverride);
Message 4 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @d.fedulov ,
As far as I understand, your model item already has a hyperlink.
Your sample code is adding one more hyperlink to the model items instead of modifying the already existing hyperlink.
If you want to modify only one model item's hyperlink, just add only the required model item to the ModelItemCollection.
Could you please try this below link to modify the already existing hyperlink in model item?
        private void Code(Document doc,ModelItem modelItem,string urlName,string urlLink)
            Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath3 oPath3 =Autodesk.Navisworks.Api.ComApi.ComApiBridge.ToInwOaPath(modelItem) as Autodesk.Navisworks.Api.Interop.ComApi.InwOaPath3;
            Autodesk.Navisworks.Api.Interop.ComApi.InwURLOverride oURLOverride = state.GetOverrideURL(oPath3,true);
            Autodesk.Navisworks.Api.Interop.ComApi.InwURL2 newURL =(Autodesk.Navisworks.Api.Interop.ComApi.InwURL2)state.ObjectFactory
            foreach(InwURL url in oURLOverride.URLs())
                url.name = urlName;
                url.URL = urlLink;
Naveen Kumar T
Message 5 of 8
d.fedulov
Hi naveen.kumar.t
I tried your code, it changes all hyperlinks of one model item in selection
I need to find only one hyperlink in selected model items and change it, other hyperlinks should remain unchanged.
where i can see the description  oURLOverride.URLs() ?  does it have get and set method ?
Items has Multiple URL I need to find one hyperlink and change it.
Message 6 of 8
d.fedulov
Message 7 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @d.fedulov ,
I think the simplest way is to check the name property by using a simple If-else.
                //only change the values of the URL having a specific URL name
                if(url.name.Contains("your urlName"))
                    url.name = urlName;
                    url.URL = urlLink;
Naveen Kumar T
Message 8 of 8
d.fedulov
naveen.kumar.t thank you very much, I understand.
