How to import XML of viewpoints?
I am trying to do an automation to create nwd with specific viewpoints xml imported. Should I simply use command line roamer.exe or use .net API ( I would use VB.net) ?  Looks like roamer.exe does not have viewpoint xml. Please advise or show me a sample code.
Thanks in advance
xiaodong_liang
Autodesk Support
Autodesk Support
no API loads the XML of viewpoint. You could parse the XML yourself to get the information of the view and configure the camera:
InwNvViewPoint.Camera
e.g. the XML has the info of the position of the viewpoint. Then we can set the position.
InwNvViewPoint.Camera.Position = oViewPos.
Hope this helps.
Xiaodong Liang
Developer Technical Services
