GUI propertys and looping trough the model
jim.marstboomB87K6
jim.marstboomB87K6
I am using COM API and I want to readout a specific GUIAtribute of all the Items in the model, and if I encounter a specific Attribute I want to Add a hyperlink to that Item.
I can loop trough the model and get all the Items, but this leaves met with inwOaNodes.
I can read GUIAtributes from a inwOaPath.
But there does not seem to be a way to convert a inwOaNode to a inwOaPath (https://forums.autodesk.com/t5/navisworks-api/inwoanode-to-inwoapath-in-com-api/td-p/9311914)
Is there another way to loop thought he model and get a list of inwOaPaths?
Thanks in advance.
Jim
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @jim.marstboomB87K6 ,
Could you please take a look at the below link?
https://adndevblog.typepad.com/aec/2012/08/addmodifyremove-custom-attribute-using-com-api.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jim.marstboomB87K6
Reading and setting the atributes is not the problem. I have trouble looping trough all the path's of the model
naveen.kumar.t
Autodesk Support
Autodesk Support
I don't exactly understand your issue.
Here is the sample code
Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
ModelItemEnumerableCollection mycollection = doc.Models.RootItemDescendantsAndSelf;
doc.CurrentSelection.AddRange(mycollection);
InwOpState10 state = ComApiBridge.State;
InwSelectionPathsColl opaths = state.CurrentSelection.Paths();
foreach(InwOaPath path in opaths)
     //Access each InwOaPath
If this doesn't help, please explain your issue in detail.
Naveen Kumar T
jim.marstboomB87K6
I was using only COM API and not the .NET API.
Your example suggests to combining both API's. I will look further into this and do some more testing.
Thanks for tip.
Jim
