Get geometry primitive in Navisworks
nasip13904
Message 1 of 9
nasip13904
Hi all,
I'm using Geometry.PrimitiveType to get geometry primitive but in this api call i am getting Triangleorline result but I want to get specific result is that line or not as I just need customize the line data. is their any way to get that
Replies (8)
Message 2 of 9
naveen.kumar.t
Autodesk Support
Autodesk Support
HI @nasip13904 ,
Could you please try using this below code?
ModelItem item=doc.CurrentSelection.SelectedItems.First();
if(item.Geometry.PrimitiveTypes!=null && item.Geometry.PrimitiveTypes is PrimitiveTypes.Triangles)
 //Your code
else if(item.Geometry.PrimitiveTypes != null && item.Geometry.PrimitiveTypes is PrimitiveTypes.Lines)
 //Your code
else
 //Your code
If this doesn;t help, could you please send me a simple non-confidential file and explain the issue?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
eduardo_salvador02
Hello!
I have another problem, If you have some time and can take a look, I'd be grateful.
I need to disable the geometry display options in the "Viewpoint" Ribbon. But I'm not finding the right method for this.
Below is the photo that I need to disable.
These are the guys I need to disable.
I'm waiting.
Message 4 of 9
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @eduardo_salvador02 ,
Do you want to disable those buttons or Do you want to turn of/off those buttons?
I tried to disable the buttons but it is not working as expected.
Here is the sample code to turn on/off those buttons
string commandId1 = "RoamerGUI_OM_PRIMITIVE_TRIANGLES";
            string commandId2 = "RoamerGUI_OM_PRIMITIVE_LINES";
            string commandId3 = "RoamerGUI_OM_PRIMITIVE_SNAP_POINTS";
            string commandId4 = "RoamerGUI_OM_PRIMITIVE_TEXT";
            string commandId5 = "RoamerGUI_OM_PRIMITIVE_POINTS";
            Autodesk.Navisworks.Api.Interop.LcUCIPExecutionContext av = Autodesk.Navisworks.Api.Interop.LcUCIPExecutionContext.eTOOLBAR;
            try
                Autodesk.Navisworks.Api.Interop.LcRmFrameworkInterface.ExecuteCommand(commandId1, av);
                Autodesk.Navisworks.Api.Interop.LcRmFrameworkInterface.ExecuteCommand(commandId2, av);
                Autodesk.Navisworks.Api.Interop.LcRmFrameworkInterface.ExecuteCommand(commandId3, av);
                Autodesk.Navisworks.Api.Interop.LcRmFrameworkInterface.ExecuteCommand(commandId4, av);
                Autodesk.Navisworks.Api.Interop.LcRmFrameworkInterface.ExecuteCommand(commandId5, av);
            catch
                System.Windows.Forms.MessageBox.Show("This tool does not appear to be supported");
Naveen Kumar T
Message 5 of 9
eduardo_salvador02
Hi!
I want to turn off these buttons, by default it is on.
I tested this code below in my environment, but it did not turn off the buttons.
Message 6 of 9
naveen.kumar.t
Autodesk Support
Autodesk Support
I tested the sample code, and it is working fine at my end.
By default, the buttons are "on". I used the above sample code to turn "off" the buttons.
I am not aware of any other way to turn on or off these buttons.
The NW engineering team said primitive display is not be exposed via the .NET API.
So, I am not aware of any other solutions.
Before:
After:
Naveen Kumar T
Message 7 of 9
eduardo_salvador02
I managed to find the problem, it was that my code is using the same thing inside a Form that overwrote the navisworks Application, preventing the code from executing successfully. I put it outside the form and it worked! Thank you very much!
Message 8 of 9
eduardo_salvador02
Hello, I'm back again, haha.
Do you know if there's any other way to disable these items other than through the command ID? I couldn't find any way to control the state of this button before executing it, and it used to happen that the button was already disabled, and then it would enable it.
I tried searching everywhere, but I couldn't find anything about disabling the rendering of Lines, Points, and SnapPoints.
Message 9 of 9
naveen.kumar.t
Autodesk Support
Autodesk Support
I don’t believe the display settings are exposed anywhere in the .NET API for direct access.
Naveen Kumar T
