Export clash result API available in latest Navisworks version?
autoDeveloper
autoDeveloper
Hello experts,
@naveen.kumar.t
Is there any update if clash results exporting APIs available in the XML/HTML format in the latest Navisworks 2021 onwards?
Thanks in advance,
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @autoDeveloper ,
Are you aiming to access the "Write Report" button within the "Report" tab of the Clash Detective UI through the Navisworks API?
If not, Could you please explain your issue using screenshots?
Also, Could you please take a look at this below link?
https://forums.autodesk.com/t5/navisworks-api/how-can-i-export-clash-report-using-api/td-p/11900777
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
autoDeveloper
@naveen.kumar.t
I understood there is no .NET API to "Write Report" from Navisworks. Between I would like to write the report XML/XLS from the options as marked in the snapshot below. Is there any API by which I can filter out the clash data.
Thanks in advance, as always !!!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @autoDeveloper ,
Is your intention to toggle these checkboxes (the ones shown in the attached screenshot) through the Navisworks API? Am I understanding this correctly?
Naveen Kumar T
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @autoDeveloper ,
I consulted with the Navisworks Engineering team, and they responded that, unfortunately, this feature is not supported by the .NET API. In other words, it is not possible to access the "Contents" from the "Report" tab of the Clash Detective UI.
Furthermore, I believe accessing the statuses is also not possible. The Engineering team added that the Clash Detective UI has no API.
Naveen Kumar T
autoDeveloper
Hello @naveen.kumar.t
Thanks for the update.
This is truly sad news for us. Please try to add into future version's wishlist.
Can you please suggest a workaround for this?
