Creating Attributes
Creating Attributes
xaotix
Creating Attributes
xaotix
Is there a better way to create custom attributes on Navisworks 2026?
The code above works fine. But in large models, he takes a lot of time.
In this new version existis something without using the ComAPI bridge?
public static void EditOrCreateProperties(ModelItem modelItem, List<Property> attributes, bool recursive)
    if(Wait.WasCanceled())
        return;
    if (modelItem == null) return;
    var tabName = BCfg.Diags.C0000;
    CreateTab(modelItem, tabName);
    var newProperties = new List<Property>();
    newProperties.AddRange(attributes);
    tabName = tabName.ToUpper();
    InwOpState10 nwState;
    nwState = ComApiBridge.State;
    // Get the selection in COM
    InwOpSelection comSelectionOut = ComApiBridge.ToInwOpSelection(modelItem.ToModelItemCollection());
    // Get paths within the selection
    InwSelectionPathsColl selectionPaths = comSelectionOut.Paths();
    InwOaPath3 selectedPath = (InwOaPath3)selectionPaths.Last();
    // Get properties collection of the path
    InwGUIPropertyNode2 tabs = (InwGUIPropertyNode2)nwState.GetGUIPropertyNode(selectedPath, false);
    // Create new tab
    InwOaPropertyVec newTab = (InwOaPropertyVec)nwState.ObjectFactory(nwEObjectType.eObjectType_nwOaPropertyVec, null, null);
    bool modify = false;
    int tabIndex = 1;
    foreach (InwGUIAttribute2 tab in tabs.GUIAttributes())
        if (Wait.WasCanceled())
            return;
        if (!tab.UserDefined) continue;
        if (tab.ClassUserName.ToUpper() != tabName.ToUpper())
            tabIndex++;
            continue;
        // Add existing properties while modifying requested ones
        foreach (InwOaProperty prop in tab.Properties())
                return;
            var match = newProperties.Find(x => x.Column == prop.UserName || x.ColumnUpper == prop.name || x.ColumnUpperOriginal == prop.UserName);
            InwOaProperty newProp = nwState.ObjectFactory(nwEObjectType.eObjectType_nwOaProperty);
            newProp.name = prop.name;
            newProp.value = prop.value;
            newProp.UserName = prop.UserName;
            if (match != null)
                var value = match.String();
                if (newProp.value != value)
                    newProp.value = value;
                    modify = true;
                newProperties.Remove(match);
            newTab.Properties().Add(newProp);
        // If the property was not found, create a new one
        foreach (var prop in newProperties)
                return;
            newProp.UserName = prop.Column;
            newProp.name = prop.ColumnUpper;
            newProp.value = prop.String();
        if (modify || newProperties.Count > 0)
            newTab.Properties().Sort();
            tabs.SetUserDefined(tabIndex, tab.ClassUserName, tab.ClassName, newTab);
        break;
    // Recursively process child elements if requested
    if (recursive)
        foreach (var child in modelItem.Children)
                return;
            EditOrCreateProperties(child, attributes, recursive);
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @xaotix ,
Please take a look at this discussion
https://forums.autodesk.com/t5/navisworks-api-forum/naviswroks-2024-vs-2025-speed-problem/td-p/13294...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
mikhail_khrushchev
        public static void TransactionWrap(TransactionDelegate delegat)
            Document oDoc = Autodesk.Navisworks.Api.Application.ActiveDocument;
            using (var tr = new Transaction(oDoc, "Custom_Transaction"))
                delegat.Invoke();
                tr.Commit();
One thing you miss - transactions.
In your case each model item will make it's own transaction - and this why it so slow.
You could wrap it into Autodesk.Navisworks.Api.Transaction . In example your code shall be in delegate.
