Bug with function GenerateImage on Navisworks Manage 2024
andrea_alpiniYNYBC
andrea_alpiniYNYBC
Hi i tried to create image by :
                using (Bitmap viewBitmap = doc.ActiveView.GenerateImage(
                    ImageGenerationStyle.ScenePlusOverlay,
                    1024,
                    768,
                    true))
                    if (viewBitmap != null)
                        viewBitmap.Save(outputPath, ImageFormat.Png);
                        System.Diagnostics.Debug.WriteLine($"[ExportSingleClashImage] Image SAVED at {outputPath}");
                        return File.Exists(outputPath);
                    else
                        System.Diagnostics.Debug.WriteLine("[ExportSingleClashImage] viewBitmap is NULL");
for me it's important to have :
1) Overlays
2) Clipping Planes on
but overlays works, Clipping Planes Not
Thank you in advance for the help
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @andrea_alpiniYNYBC ,
I don’t quite understand your issue. Please explain it in more detail.
You mentioned using GenerateImage with Navisworks Manage 2024 — can you confirm the exact version you're working with?
Have you tried generating the image manually through the Navisworks UI? Does it produce the correct result?
Is this issue happening only when you use the API?
Also, please share both the expected output image and the one you're currently getting. This will help in identifying the discrepancy.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
andrea_alpiniYNYBC
Hi, thanks for your reply,
i'll try to clarify the issue.
1) version used : manage 2024 Update 2 Version 21.2.1413.45
2) problem  is present using API ( i need to develop new plug-in in c# using API that shall export images with Overlay and Clipping/Sectioning).
                    1024,
                    768,
                    true))
the true flag should be turn on the Sectioning but not works (see the attached files)
by API the sectioning not work( the green pipes appear but are outside of clipping volume)
by UI the clipping (sectioning) works perfectly.
this issue was already notified in Navisworks 2023
Solved: Bug with function GenerateImage on Navisworks 2023 (v20.2.1393.45 only) - Autodesk Community
Hope this help
regards
naveen.kumar.t
Autodesk Support
Autodesk Support
I just checked our internal tickets but couldn’t find any similar issues reported previously for Navisworks Manage 2024 Update 2.
I’m currently using Navisworks Manage 2024 Update 3.
I tested the scenario using the files I have, but I wasn’t able to reproduce the issue.
For now, I recommend that you send me a simple, non-confidential sample file.
Since you’ve already shared the expected and observed results, I’ll test the file in my environment and update you with the outcome.
When sharing the file, please also specify which viewpoint I should use for testing, so I can accurately check if the issue is reproducible.
I’ll run tests in both Update 2 and Update 3 and let you know the results.
Naveen Kumar T
