Calling Navisworks Commands using Command ID
alexisDVJML
alexisDVJML
Seems similar question has been asked in the past, without reply:
https://forums.autodesk.com/t5/navisworks-api/call-navis-commands-from-our-add-in-ribbon/m-p/8014920
However it would be very useful, so asking again 😉 with a little bit extra details.
RoamerCommands.xml file contains a list of Roamer commands, exemple:
<Command ID="RoamerGUI_EDIT_RESET_COLOUR" />
So the question is simple,  how to run a CanExecute and an Execute using a Command ID string?
I really try hard to find before reverting to asking, hoping we can get help on this.
Main Scientist, Full Stack Developer & When Time Permits Director of IDIGO ► On your marks, Set, Go
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @alexisDVJML ,
Please take a look at the below link
https://www.houseofbim.com/posts/naviworks-net-executecommand-method/
Here is the sample code that worked for me
private void MyCode(Document doc)
            string commandId = "RoamerGUI_EDIT_RESET_COLOUR";
            string commandId2 = "RoamerGUI_EDIT_OVERRIDE_TRANSPARENCY";
            Autodesk.Navisworks.Api.Interop.LcUCIPExecutionContext av = Autodesk.Navisworks.Api.Interop.LcUCIPExecutionContext.eTOOLBAR;
            try
                Autodesk.Navisworks.Api.Interop.LcRmFrameworkInterface.ExecuteCommand(commandId2, av);
            catch
                System.Windows.Forms.MessageBox.Show("This tool does not appear to be supported");
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
alexisDVJML
@naveen.kumar.t  Excellent, Thanks!
alexisDVJML
@naveen.kumar.t Tested, working, thanks!
BIM-ZhagnXuetao
Hi, there is a problem I got. I want to post the parameter to the commond. However I have no idea how to post.
Below is my code.
string commandId2 = "RoamerGUI_OM_MEASURE_PT_TO_PT";
try
catch
BIM-ZhagnXuetao
try
catch
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @BIM-ZhagnXuetao ,
Please follow the steps outlined in this link
public class MainClass : AddInPlugin
        public override int Execute(params string[] parameters)
            //Place the code here
            return 0;
Naveen Kumar T
