Call Render plugin through AddinPlugin
cerqueira.tiago15
1,701 次查看
3 条回复
1 条消息(共 4 条)
cerqueira.tiago15
The method R(view, Graphic) generates spheres in some coordinates. This is the only way that I have found to generate a sphere solid inside Navisworks. Therefore, I would like to call the plugin bellow through another AddinPlugin but I am able to do that only using ToolPlugin instead of RenderPlugin. As I don't want to override none of the tools available for the user navigate, this is the better way I have found. Is there a way to call it? If not, is there a better way to create geometry inside Navisworks?
class SpherePlugin : RenderPlugin
    public override void Render(View view, Autodesk.Navisworks.Api.Graphics graphics)
        R(view, graphics);
    public override void OverlayRender(View view, Autodesk.Navisworks.Api.Graphics graphics)
        R(view, graphics);
0 个赞
已接受的解答 (1)
1,702 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
不适用
已接受的解答
As far as I am aware, the render methods you've linked are called every time Navisworks attempts to update the frame (from mouse click, etc.) What I think you could do is something similar to the following:
    public static <Object you want to render> Renderable = null;
        if(Renderable != null)
            // Do your drawing here
        R(view, graphics);
        R(view, graphics);
In this scenario it checks if there exists something needing to be drawn, and if it doesn draws it.
You calling code could then set renderable to whatever needs to currently be drawn, or to null to stop something from being drawn.
I know this seems very hacky and super inefficient but it's the best thing I've found to work for when I attempted this in the past.
3 条消息(共 4 条)
cerqueira.tiago15
It works. Thanks a lot. Instead of null I use a non static variable to be evaluated during the call of the plugin.
        public override int Execute(params string[] parameters)
            if (enable)
                RenderPluginRecord toolPluginRecord = (RenderPluginRecord)Application.Plugins.FindPlugin("MyPlugin.TIAG");
                RenderPlugin plugin = toolPluginRecord.LoadedPlugin;
                SpherePlugin spheres = (SpherePlugin)plugin;
                spheres.isRender = true;
            else
                spheres.isRender = false;
            enable = !enable;
            return 0;
And in the method:
        public bool isRender = false;
            if (isRender)
                R(view, graphics);
            if (isRender)
                R(view, graphics);
4 条消息(共 4 条)
HusseinOthman75
How could you reference render plugin : SpherePlugin in the Addin Plugin?
0 个赞
