The problem starts with the fact that Nastran In-CAD results viewing is very slow - I've had analyses in the past that took up to 30 minutes to load a results view (on a proper CAD workstation btw). As a result, I've started using Nastran Editor for results viewing. In my current analysis results display in Nastran In-CAD takes almost 3 minutes per view change (results type, scale change etc). The same analysis in Nastran Editor is almost instant.
However, Nastran Editor has a painfully limited legend editing functionality. Nastran In-CAD allows you to set upper and lower limits to the scale (shading out of range areas in a different colour) - which is extremely helpful for identifying regions which exceed allowable limits. This isn't possible in Nastran Editor.
Please enable the editing of upper and lower scale limits in Nastran Editor AND for those regions that fall outside this range, render them in a different colour (e.g. white or user customisable).
Related forum post: https://forums.autodesk.com/t5/nastran-forum/editor-model-results-color-contour-customization/td-p/5...
