The Nastran Ideas Board will be archived on November 14, 2019. Please submit any ideas to the Inventor Nastran Ideas Board instead.
Gluing (weld) shell edges
It would be extremely helpful if a joint between two irregular meshes with common edge geometry in a FEMAP model could be glued or welded together. This would help keep element size down and help reduce model setup time.
1 Comment
mitch.muncy
Status changed to: Accepted
