Hi @dido32511
It looks like you have it setup right. I would create the shell idealization with the laminate material and assign the idealization to the surfaces of the solid part where I was adding the reinforcement. You will want to mesh after all the idealizations are done, and if I remember correctly, you will want to use the continuous meshing option.
James
James Kubli, P.E.
Please marked this as solved if your question has been answered.
