Because my wing has a wingtip winglet, I fill in the aerodynamic surface in sections.But when I used Nastran to calculate the linear static deformation of the wing, the aerodynamic surface of the original joint broke.Does it affect the accuracy of the results?How to solve this problem? Thank you very much for your guidance and advice!!!
Hi @1518897137 Welcome to the Autodesk Inventor Nastran forum.
I see that you are not using Autodesk Inventor Nastran to create your model. What software are you using for creating and viewing the results? I suggest that you should contact that software vendor and ask why the pieces of your model are not connected together.
John
